Try this two-steps approach:1. Select all blue/black polygons B which are in large green polygon A using Select By Location from Selection menu.2. Use Summary Statistics tool (Analysis->Statistics->Summary Statistics) to calculate summary area for each type of polygon B with settings: - Statistics Field: Shape_Area - Statistics Type: SUM - Case field: type field - the field based on which you differentiate polygons color.
worked fine thx!I just used as type field my "capture date" and in fact, that the format is sometimes dd.mm.yy and sometimes with dd.mm.yy + time I got seperated values. Can i drop the time before in my attribute column?
To drop the time: create new column and use this simple expression in Field Calculator with Python parser:!ErfassungsdatumBy the way, if you've found my previous answer helpful, mark my post as answered using voting tools:
